TwinTurbo.NET: Nissan 300ZX forum - short plugs are fine in NA heads, i cant agree with TT heads
Dane (Houston)
on February 26, 2013 at 4:39 AM
I JUST figured this out as well. They work for both TT & NA
posted by ZinnZ32
on February 25, 2013 at 07:39 PM
also TT heads with bowl/dome work (combustion camber work) where the spark plug bose is removed should run the short plugs as well because the dome is raised after this sort of modification.
Houston Z
www.houston-nissans.com
In search of a definitive answer: NA heads on a TT Block
ZinnZ32
16:04:13 02/25/13
Bkr7eix are shorter than pfr6b-11b. they are same length as
Krazyd27(Houston)
17:49:26 02/25/13
ZinnZ32
19:39:29 02/25/13
short plugs are fine in NA heads, i cant agree with TT heads -
Dane (Houston)
04:39:46 02/26/13
Wonder why SZ reccomends the BKR plugs if shorter? (n/m)
ttsmokin
23:11:45 02/26/13
Info inside.........
Greg D. (Specialty-Z)
12:14:49 03/01/13
good to know. (n/m)
nemo1080 (Iowa)
15:41:11 03/04/13
